biminiLX
I didn't post those spring pics, but those aren't stockers are they?Your assertion that racing is a more severe environment is absolutely wrong. How much snow, rain, salt, rocks, ect. do race cars drive through? How often is a suspension in a race car inspected? How often is yours? How many miles does a race car go before changing springs. How many miles do want yours to go, how many years? How many potholes and curbs will a race car hit? How many will car hit? The amount of damage you will do to spring is much more than a racing team would place on a spring.
How are you planning on painting it. In the OEM world they are e-coated or powder coated. E-coat is only a marginal paint for springs. Powder does well. A can of Rustollium does very little.
The springs bimini showed have a variable coil diameter. If you cut those the spring wouldn't fit in the spring seat correctly.
From the search I did, stock is also linear rate correct?
You are correct on the race vs. DD statements, but certain forces will be higher in a race environment. Everything would be inspected 2-3x yearly.
The rate increase really would be negligible with one coil removed, I'm not worried there.
You got me, I did just rattle can after cutting, but usually there will be an isolator at the perch that covers the end.
Back to topic though, can I cut the stock springs 1 coil at the top and have them fit in the spring seat? and how much will this 1 coil lower the car (on good low mile OEM parts)?
-J
