The setup i am looking to get is three MTX 4500's in a sledehammer enclosure. Each of these takes about 225 watts rms and the box has three 4 ohm connectors (one for each sub). My options are to use it as is or wire the entire thing into one connector and have a 1.34 ohm load. I'd much rather keep it 4 ohm.
Anyway, as i see it, having 3 connectors i would need 3 channels or an individual amp for each one. I finally came to the conclusion that a 4 channel amp with one channel unused would fit my needs the best. With it being 4 channel though, I'm unsure as to what wires need to come from the HU to the amp in order to provide for all 4 channels. Normally there would be a single wire going into your typical red and white ports on the amp, but when i look at the pictures of the amp, i see 2 sets of these connections. (channels 1-2 and channels 3-4.) What would i need to do?
http://www.sonicelectronix.com/item_10234_Lanzar+MXA422.html# <amp
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=510&i=236T4510X3&tp=112 < subs
