+ Reply to Thread
Page 1 of 2
1 2 LastLast
Results 1 to 10 of 11
Thread: Sunroof cover - fix broken tabs
  1. #1
    Default Sunroof cover - fix broken tabs
    i have recently figured out a way to fix your broken sunroof cover with as litte, time and effort, as possible! Mikey P came by my house today and we're using his car as an example. all you need is 2 "L" brackets and 2 pliers, a phillps head screwdriver and the original screws that hold it in place
    first, a pic of the cover we were dealing with
    and these are the brackets we used...they measure about 1 1/2 inches on each side one is already bent to fit the cover, and one is not yet, just to show you what they should look like
    the next pic is of me bending the one bracket
    these next 2 pics shows the brackets installed with the original screws, only 2 screws are required! install the cover, attach the rear clips back into place! the two screws in the front, after installed, will actually pull and slightly stretch the cover a bit and make it very tight! JUST DONT NOT OVER TIGHTEN THE SCREWS! USE YOUR JUDGEMENT ON HOW TIGHT THEY SHOULD BE! make sure the brackets are flush with the cover and your dome light will slide easily back into place! no cutting, or drilling required! just bending is all thats needed here!
    this last pic, shows its complete!
    this is a very very easy fix, its much much better than stock and you'll never have issues with it again!! it only takes a few minutes to do! i did it in my car and in Mikey P's car as well!
    hope this helps! enjoy!
    1998.5 Contour SVT 6221/6535-CF hood-DMD-KKM-MSDS Y-TRUBENDS TEST-B&M Shifter-
    owned, sold then totalled #4265=deceased
  2. #2
    Join Date
    Oct 2009
    romeoville, il
    Posts
    774
    Default
    thanx for the post. ive been trying for awhile to figure out away to do something. i saw this & realized i have some of those L brackets so i did it today & it worked great. I drilled little holes in the cover to screw the cover to the bracket thou. held real nice & sturdy. especially since b4 i only had 1 of the slide on clips holding it up. it was just dangling all the time. u had to hold it just to turn the light on.
    98' Black CSVT #618 3L, Torsen, B&M, Intake, Borla, BAT Supension
    98' Silver Frost CSVT #2582 -SOLD
    99' Black CSVT #1807 -TOTALLED
  3. #3
    Join Date
    Aug 2010
    Philadelphia PA
    Posts
    42
    Default
    I am just stopping in to let everyone know its been holding up great. It has been about two weeks and everything is holding up just fine. Everything is nice and tight! Glad to see double u 4 tryed it already. Thanks again for makeing it a how to and thanks Joe for makeing my car the guinea pig.
    SVT EO black/MN blue
  4. #4
    Join Date
    Mar 2003
    oneonta ny
    Posts
    4,857
    Blog Entries
    1
    Default
    fiberglass is another very easy and very strong way to do it, its what i did to mine, and did some spares too.
    --current cars: 1998 contour svt # 0165, 2009 mercury mariner premiere
    --past cars: 1996 contour se, too many mods to list!!, 1999 silfro svt, 1999 tropic green svt, and tooooooooo many others to list.
  5. #5
    Default
    Quote Originally Posted by mikeyp View Post
    any time bro, this IMHO is the best, easiest, quickest, and most durable way of fixing this problem with our cars! mine is still holding very strong too! i hope it helps others!
  6. #6
    Join Date
    May 2005
    Durham, NC
    Posts
    629
    Default
    Thanks for this post! I had to deal with the same problem, but in a pinch I just used crazy glue to reattach the tabs. It's held up for several months now, but it's less durable than this method so if it ever breaks again I'll be fixing it this way instead.
    E0 Silver Frost CSVT #3095/6535
  7. #7
    Default
    A word of Caution to all us Rookies- That tab/bracket you are bending is METAL, and so is the contacts for your lights. If you don't bend it correctly, or high enough, when you put the light back on the lgith and other assorted electrical may not work-because you created a ground and blew the fuse.
    THEN you will find out what a joy it is to look for a fuse panel under the dash...some would even take the dash kick panel under the steering wheel out to get at the fuse block-and then push the stupid black button to get the fuse panel to pop down..what the F is with that???!!!
    I'm not saying that's what I did...I'm just saying..
    Mike sheepishly back away from the forum
    Mykdee-
    1999 Ford Contour SE Sport
  8. #8
    Default
    Quote Originally Posted by mykdee View Post
    ABSOLUTELY FALSE.....i have done this on a few contours and never had one issue with the contacts for the lights.....there is PLENTY of clearance in there to easily reinstall the light, i haven't blown one fuse yet! this is very simple and easy to repair this annoyance with our cars...there is nothing to worry about! if your tabs are broken, follow this how-to...i know many will agree that its a great fix!
  9. #9
    Join Date
    Mar 2001
    Merrimack NH
    Posts
    10,408
    Default
    If you're worried about clearance, a bit of electrical tape placed over the contacts (as seen in picture 4) should keep the two separated.
    Matthew
    1999 Contour SVT #410 - 109k
    2008 Subaru Legacy GT Limited 5MT - 130k
    Sold: 98.5 Contour SE V6 ATX
  10. #10
    Join Date
    Feb 2010
    Halifax, NS
    Posts
    99
    Default
    Pretty nice fix.
    I can recall when I snapped mine off, from tightening the screws too tight on the old rotten plastic. I gathered the pieces I could, and put them all back together with painters tape holding everything in relative order, then slapped a good thick layer of epoxy on top of it all, and filling in the voids where I did not have plastic pieces. Basically made an epoxy mold. But I do like the idea of the metal tabs... Because a year later after installing a pioneer deck, I wish to velcro the remote to the sunroof panel so I can grab it and detach it when driving, and replace when parked. But, I do not trust my epoxy molding. Maybe time to reconsider. But... we all know "temporary is permanent..."
+ Reply to Thread
Page 1 of 2
1 2 LastLast
Similar Threads
  1. Broken tabs on plastic door sill trim
    By hotdimmes in forum General Discussions
    Last Post: 03-23-2014, 01:38 AM
  2. Sunroof cover - fix broken tabs
    By ukravit in forum Exterior and Interior How-To
    Last Post: 04-21-2013, 01:21 AM
  3. broken E0 center cap tabs. repair?
    By hallfleming in forum Wheels and Tires
    Last Post: 05-25-2011, 06:43 AM
  4. How to fix broken headlight mounting tabs
    By svT-Rex in forum Exterior and Interior How-To
    Last Post: 12-25-2009, 10:31 PM
  5. All top Headlight tabs were broken off
    By ottoschutze in forum General Discussions
    Last Post: 07-18-2007, 09:52 AM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
