99Mystique ATX
What did you use to fill it? If you didn't, you may want to try getting some of the 94A poly and cutting out what you have in yours and just pouring in the 94A. As long as surfaces are clean, you should be fine...
On a side note, i'll be installing my mounts when I get out of class tonight and hopefully have the car on the road early next week...
My repaired mount is starting to break... There is just not enough structure on the older mounts for this to work![]()
Now I am bucking again, arrg![]()
