bhiggs89
I'm just curious was you using 3l heads and was the injectors you was using for a oval port or split port? Cause if you was using split port injectors in a oval port head maybe it's as sicse suggested that the one piston looks like the fuel wasn't atomized. Which is what would happen if using split port injectors In Oval port heads
Please add the term "were" to your vocabulary.
