BAD SVT
Addicted CEG'er
Did you replace the cam caps on the right sides and in the correct order?
yup. positive. they are even numbered.
Better to feel a little silly now making SURE you have it right, then feel a little silly later with a bunch of bent valves. :blackeye:
Sorry, but do NOT leave the cam caps loose when you're timing the engine. Make sure you've got some fresh lube on all cam journals & torque the cam caps to spec. These are some of the most important bolts on this engine to torque to spec, IMO... and it's done BEFORE installing the chains.
Bank 2 looks good, (bank on the right in the pics, for any who are unsure), but if you've spun the engine over, being that the tensioner is not installed, I would double check it as well. Bank 1 is WAY off, BTW, in respects to bank 2. The first thing you should do, is install the crank pulley bolt into the crank so that you can spin the engine with a wrench, (pulling the spark plugs also makes it substantially easier, as I think someone already mentioned). Remove your bank one chain & double check the timing marks on bank 2. If you can still see the different colored links, then just make sure they line up, if not, count the links in the chain, following a clockwise direction from the crank. The crank keyway link is the zero link. The 29th link from the crank keyway link is where the bank 2 intake cam mark should be. The 42nd link from the crank keyway link is where the exhaust timing mark should be. Make sure your timing is right for bank 2, install the tensioner & pull the pin to put tension on the chain. Once you've got the timing set for bank 2, spin the crank only enough to line up the timing marks for bank 1, (counterclockwise in your case). If the crank won't spin far enough to line up the timing marks, you've got piston-to-valve contact & you'll have to back the crank up some & rotate the cams to put the valves in better position. Once bank 1 is lined up & tensioned, spin the crank clockwise to where bank 2 timing marks are @ 9 & 12, and make sure bank 1 marks are where they're supposed to be.
thanx man. i'll go try again.
