elraido
I kant speel
one issue with a convertable is the more complexity of the top, hence, more things to break. hmmm
NOt to mention heavier.
Saturday at 1PM.
Start driving with your tinted windows down
Yeah - drive around with the rear windows down just makes it more obvious. Trooper didn't care about my front windows (37%) but he didn't like the rear 3 windows (10%).
Oh - and you idiots who dont know the law - they measure how much light goes through the glass, hence why they slide over a light with a sensor on it. 50% fron and rear is what is legal which is worthless - I'm going to retint the rear with the same film that is up front. 125 bucks down the drain...
Have fun guys - I wont make it this year. I'd easily spend 100 in gas - I've got an untuned 3L with a clogging fuel pump. On my way to Spring Zing I was able to get 28.5MPG's - Get gas, set cruise to 75, take cruise off just to drive intot he gas station. Started palying around and got 21 MPG's - I spent close to 350 on my Michigan trip...
Is that a challenge?so dont worry about me slowing anyone down
So thoughful of you :laugh:(and if need be, i can haul some boards for tony to make it over bumps
unfortunatly, it wont be ready by friday. so i guess i'll be rolling in the subaru.
Only cool cars can go...............I guess I will bring the wifes subaru as well. Might as well make it a subaru party instead. :laugh:
I've got about 25% all the way around. I've been ticketed before near university ave. If I'm worried about going someplace like that I just roll down my front windows all the way, then remove the window switch from the driver side, unplug it, reinstall. If you get pulled over just tell them they don't work :laugh: (none of the window switches will operate if that's unplugged). They can't use the reader that slips over the glass if you can't roll the windows down! And the fronts are all they should care about anyways (trucks you can have darker than 50 in the rear, what defines a truck?) , if the fronts are down they shouldn't be complaining.
i was pretty sure that in MN the fronts have to be at 50% and the rears can be as dark as you want... hmm, i think i'll have to look it up. my moms scuby has about 35 ont he front, and probably 20 in the back. its on a white car too, and it is real obvious. i got pulled over once for speeding and he measured the tint, but becaue it want my car, he didnt give me a ticket.
oops, nevermind, i just looked it up.
http://www.tintcenter.com/laws/MN/
Make sure you order from Steve at Tousley if you're going through the trouble of ordering them. I thought they were more like $100/pair.Instead of using those used springs, I am going to order new ones. $140ish for the two rear ones. I am just having second thoughts about used/rusted springs when i am going threw all this to have a shop replace them. Get it done right the 1st time. I am going to finish reclaiming them though if someone wants to buy them. Told they have around 40-50K miles?
It was very easy. I think I just had to take one screw out of the door panel IIRC. I used to keep a screwdriver in the door panel compartment :laugh:Hehe - thought about that myself - how do you easily gain access to that plug?
