Captain Caveman
(Suggestions to add to this list are welcomed)
General FAQ
CEG FAQ Documents
CD4E General FAQ
CD4E FAQ -- the Master Plan, man! (link is from this thread, which also has a bit of good info)
CD4E PDF files
CD4E ATSG Manual
CD4E Info Links
CD4E Info Link (motocraftservice)
CD4E ATF Cooler Pics
ATX Rebuild Picture Story (without pics, sadly)
Transmission Fluid
Hayden #404 Cooler for CD4E redir
Transmission fluid change
Shifter
Transmission - Reduce play in manual shifter
Clutch
Checking the clutch during test drives
Clutch Failure Links for Luk and Spec clutches
SE vs SVT Clutch
MLPS/TRS
MLPS/TRS locations (basic idea anyway)
- Under the front of the battery. It will have a rectangular electrical connector going into it. (props to "andreslobo")
- for the v6 I had, pop the hook, under the accordion pipe you will see a sensor on top of the transmission, its that sensor. (props to "starjammir")
Question about MLPS Part # and Pigtail (useful)
MLPS/TRS Alignment
VSS
finding the Vehicle Speed Sensor (VSS) on CD4E (read carefully)
Will add more as I find it, or... feel free to add a LINK to a useful thread, please.
General FAQ
CEG FAQ Documents
CD4E General FAQ
CD4E PDF files
CD4E ATSG Manual
CD4E Info Links
Transmission Fluid
Shifter
Clutch
SE vs SVT Clutch
MLPS/TRS
MLPS/TRS Alignment
VSS
