Page 1 of 2
1 2 LastLast
Results 1 to 10 of 16
Thread: Clutch check?
    Jan 2008
    Bay Harbor Islands, FL
    124
    Default Clutch check?
    Hi,
    I am in a bit of a Contique crisis, I need a car quite quick, since I am gonna move next week, and still don’t have a car, and was too busy to look for one so far.
    I found a ‘99 Mystique in my price-range, but it is a manual. I don’t mind that too much, since I learned how to drive it in Germany. Yet, my experience is that folks over here don’t quite know how to drive them, cause I hear them all the time burning the clutches. So I don’t wanna end up with clutch issues (how much would it be on a Contique?).
    Is there a way to check the clutch prior to purchase that even a layman like me could do? I was told to pull the handbrake, and than slowly release the clutch in the highest gear, and wait for something funny to happen. Is this advisable?
    I really wanna show the car to a mechanic prior to getting it. Since I don’t know any mechanic in Miami, do you now any nationwide ‘chain’ (dunno, Midas or Meineke?) to which I could trust for a check?
    Thnx very much folks,
    Just take it for a test drive, you should be able to tell if it's slipping or has any problems.
    -Matt
    2010 Subaru Forester
    '99 Tropic Green LX, Zetec, ATX (for sale, see classifieds)
    Dec 2001
    Enfield, CT
    20,539
    Blog Entries
    93
    set the parking brake and use 4th gear. realease the clutch and if it stalls the clutch is good if it doesn't stall or drop the rpms the clutch is slipping ....
    other then that just drive it and see what happens.
    and about burning clutches out .... I have 200k on my stock zetec clutch and I put 100k on it .... my fathers 95 has 150k on the original clutch ... another member here put over 200k on his clutch also ....
    chances are if it was driven right a spring in the clutch or pp will let go before the clutch material burns up ...
    - 95 Mystique LS
    - 2k Contour SVT - #2137
    Aircougar Performance
    Mar 2004
    Louisivlle Ky
    5,212
    yup, i had 241K miles on my stock zetec clutch before one of the dampening springs blew up. when i pulled it the clutch still had plenty of material left on it as well.
    '00 Black SVTC #391
    Now For Sale
    '97 GL Turbo Zetec - gone
    Sep 2007
    Dallas, Pennsylvania
    908
    164,000 on stock clutch on my mystique and it grabs just as good as ever
    Alex
    01 Cougar MTX Zetec - RSTB/KYB Struts with H&R Springs/B&M Short Shifter/SleeperZ/UDP/Weapon-R Header
    on the zetec, wearing out a clutch is a hard thing to do, my pre98 had 140K on the stock clutch, my 99 had 170K on the stock clutch.
    Gone.
    Quote Originally Posted by AliasJerk View Post
    cuz there's not that much power? lol
    Cardomain page!
    '97 Contour - white - zetec - mtx
    mods: led clock, short shifter, custom fabricated shifter knob, cold air intake, basic stereo/speaker setup, partially painted interior (work in progress), mesh grille, straight piped exhaust
    Mar 2004
    Louisivlle Ky
    5,212
    IMO its cause ford over engineered the pre98 contour. that or they underengineered the 98+ ones.
    '00 Black SVTC #391
    Now For Sale
  9. #9
    Quote Originally Posted by Fordwerke View Post
    Hi,
    If the clutch feels smooth and grabs predictably and crisply, you know it'll hold up to whatever you throw at it. Clutches in these cars last a long time if they're not beaten on, as others have attested. Don't waste time and money having a shop give you an opinion on a part they can't even see without significant and costly disassembly. The pedal should engage and disengage smoothly, and you should feel the clutch start to catch roughly half way up the length of the travel.
    If you really want to torture test it, take it a few blocks in afternoon rush hour traffic on the Tamiami Trail or the Palmetto (gasp!).
    2000 Tropic Green Contour SVT
    1994 Opal Frost Taurus SHO -- SOLD!
    "Have you ever seen a spleen that large?"
    "No -- no -- not since breakfast."
  10. #10
    Oct 2004
    Northern MN
    7,715
    I also thought Ray had a "how to" sort of thing to tell. It went something like this
    In 1st gear get it up to around 15 mph.....shift to 5th and hammer the gas. If the RPMs climb faster than the speed, than you have a slipping clutch.
    99 3.0L SVT Silver Frost #1264 Sold 1-22-10
    99 Lincoln Navigator
    99 Toyota Solara And one Peppermint Patty
    95 SE MTX---Sold 9/14/07 sniff
    98 E1 SVT #4892 of 6535T-Red Sold 8-29-08
