Ok, so i'm experiencing some very strange electrical problems after driving through the rain today.
Before the rain, my car was perfect, everything functioning normal. Tonight after the rain three things are happening:
1. My high speed and low speed cooling fans stay on at all times when the engine is turned on. When you fire the engine up, in about three seconds both cooling fans start up and stay on until you kill the engine.
2 & 3. My wipers and passenger side fog lamp are going crazy....the wipers and passenger side fog lamp (thats right, just the passenger side lamp) turn on every 4 seconds when the key is in the on position (regardless of whether the engine is on or off). So when the wipers get powered up every 4 seconds, they will run for about 1 second and stop at a different spot in their cycle each time. The one fog powers up in unison with the wipers.
I dug into the wiper issue and found that the pulsing is probably a result of the circuit breaker in the interior fuse box...if i touch it i can feel it switching on and off ...what i think is happening is that the circuit must be shorting somewhere and as a result too much current is going through the circuit breaker and it heats up and opens the circuit, then cools and connects the circuit again momentarily and continues on in this way...like a thermal flasher relay. When i pull the circuit breaker out, it stops both the wiper and pass. fog. Along with all this fun stuff the wiper switch no longer does anything, and when you turn on the fogs from the switch only the driver side turns on. What the hell? :help:
Oh and as for the cooling fan issue this happened once before after driving through heavy rain, and the car ended up sitting for about 2 weeks, and the issue went away on its own....at the same time that this happened i had an issue with the passenger side airbag sensor shorting to ground...i couldnt find the short, so at the time i just ended up re-running all the wires from that sensor to the airbag control module in the cabin and fixed it...i know it was a band-aid fix, but i did what i could at the time.
I'm kind of at the point where i'm not sure what to do.
All i could think is that maybe there is a problem in the wiring harness that goes along the fenders and front of the engine bay...seems like within that loom is the wiring for the fogs, airbag sensors, and cooling fans...maybe there is a short within the wiring....maybe i have the deteriorating insulation problem that there was a recall for on the pre98s? my build date is 2/98 though...i really dont know where to go from here. :help: :help: :help:
If you've made it this far, thanks for reading! ANY ideas/thoughts/help would be appreciated.
