are you talking about the marcel spring? there's not much to the stock SVT one there either and the material on the SVT one is thinner. I think folks aren't getting the point. everybody is comparing this clutch to $350+ stage 3 parts when it's a $275 stage 2, only 50 bucks more than the stock clutch. none of the windows are closed on the stock clutch, there's a thin marcel spring on the stock clutch, there's less rivets in the stock clutch, and I'm waiting to find out if the stock clutch has a lower clamp load. the question here isn't if this clutch is stronger than a stage 3+ from a high end company, the question is if it's stronger than the stock clutch, and from the pictures Id say it still is.
and if you really want a clutch with no marcel spring, the SE stock disk doesnt have one, just one big plate of steel with the organic material on it and a sprung hub...
