BAD SVT
Addicted CEG'er
thx for the ideas y'all. on second thots tho; considering heat is a major issue out here, i really dont think i should be skimping out on a radiator, right? or is it just paranoia on my part?
If you have a decent pair of channel locks, (and some patience!), you can bend back the tabs that hold the tank on, so that you can remove the tank and work on both sides of the hole. Then you can use a backing nut as already mentioned, along with some sealant and the threaded nipple for a repair that's as reliable as you can get. You'll be done quicker, cheaper and almost as reliably as a new rad.
Correct... it's a small, elongated, plastic bathtub. :laugh:its open on the side that attaches to the metal surface. sorta like a 'U' shape. correct?
Or if youre really wanting to hear it start just go ahead and start it. Its not like its going to over heat in 5 mins or something with out a radiator. Just start it and let it run till it gets norm or close to norm operating temp just to make sure it runs smooth and shut it off.
You could just take it to a local radiator repair place, they might have a better solution for you.
Personally thats where I'd start.
-J
That is exactly what JBweld looks like if you let it fully set without disturbing it, then spray paint it... ask me how I know. :laugh: The same can be said for most epoxies though, so you'd have to remove some paint and/or grind on it to be sure of what it was.that isn't JB weld by a long shot.
Can't beat that!25bux![]()
