2000 Contour SVT for sale
This is a very, very nice example of a CSVT and a very reliable car. It has ~92,000 miles that have been mostly highway miles as the last 2 owners (total of 3) have lived far from work. This car has had easily over $12,000k put into it over it's lifespan.
I am selling it to get another Mustang and to get out of driving a stick shift everyday on my long commute. It is a sweet car and I would be happy if it could sell to a fellow enthusiast who will take care of it. Anyone who knows me knows I only by nice stuff and I take care of my things. It has been meticulously maintained by myself and the other owners and has been waxed more times then most people would do to all of their cars over their whole life.
The car currently has a Pioneer AVIC N3 installed which I will be replacing wiht a very nice new head unit (just not a flip up screen type).
The car was dynoed at 181hp and 173tq. The first owner was an active member of this board so some of you may be familiar with the car.
The car only has a few minor issues which could be easily addressed.
1. The left side blinker sometimes blinks rapidly.
2. The billet fuel door hinge broke (victim of the cold weather) somehow so the door is not sitting properly so it just needs to have a new door bolted on.
3. The power antenna needs to be replaced. I have it disconnected because I have Sirius satellite.
If I was to nitpick I would say it needs fresh springs and shocks because it does bottom out in back on a good bump. Also could use fresh stripes. But this is really nitpicking guys because the car is in great shape. The owners of this car have spared no expense in the maintenace of this vehicle. It was only about 2 months ago I spent $2500 at the dealership getting a few things repaired to make everything just right.
Here is a list of mods, service work, and some exterior pics (from the previous owner). I will try to get some recent exterior and interior pics soon (you won't be dissappointed).
MODS:
8" dark blue racing stripes
Milan quad projectors headlights - 90mm and 80mm Hella (4100K Philips HIDs)
Eurolite fog light bulbs
50% window tint
B-pillar decal mod
Aussie grills (Stainless mesh for front and rear)
new moonroof motor and custom delrin gears made
body color grill ring
custom SVT grill emblem
Audi A4 sidemarker lights
"knauberized" (Removed Door Ding Strips)
pre-98 sail panels
pre-98 antenna base
PIAA superwhite back-up lights
rear valance painted to match car
17" BBS RX Wheels
painted calipers w/Ford blue engine paint
carbon/ceramic brake pads (might be Hawk brand)
Magnaflow custom made X-pipe/woven Magnaflow compression pipes/gutted pre-cats
BAT pipe w/ 9" K&N & BAT MAF adapter
KKM billet oil cap
R1 pedals
B&M short throw shifter
"Krafty" custom-made shift and e-brake boots
VooDoo shift knob-powder coated white
BNoon white faced HVAC
Focus Ford logo on the steering wheel
Stainless Steel Braided Brake lines
BAT/Bilstein Suspension Combo (car sits 1" lower than stock) (Suspension installed by ATI of Troy, MI (Maker of the original V8 Focus)
urethane bushings
reinforced and boxed in fully welded rear subframe (according to original owner-have not conformed this)
19mm Solid Aussie bar w/urethane bushings
Ceramic coated 3rd gear synchros
Ford Racing Plug wires
Optimized Throttle body
MIL eliminators
Focal 165A1 6.5" component speakers for front
Focal 165CA1 6.5" coaxial speakers for rear
JL Audio 10W1V2D4 10" subwoofer with custom fiberglass enclosure
SERVICE AND MISC. WORK (by mileage):
12,000 transmission fluid flush, coolant flush, powersteering fluid flush, 4-wheel alignment
21,000 transmission fluid flush, coolant flush, 4-wheel alignment
30,000 water pump impeller changed to new metal type
34,000 brake fluid flush, clutch fluid flush
41,000 transmission fluid flush, powersteering fluid flush, 4-wheel alignment
new starter
new battery
54,000 suspension components installed, 4-wheel alignment, front wheel bearings replaced, upper and lower intake manifold cleaned (removed from car and dipped by Ford)
59,000 transmission fluid flush, coolant flush
new moonroof motor and delrin gears
62,000 4-wheel alignment
75,000 replaced windshield wipers
76,500 replaced rear taillights (originals were melted)
76,500 cleaned and oiled air filter
77,400 Fuel pump and fuel filter replaced
80,600 Emmissions tested-passed
80,700 Replaced right side HID bulb (4300k Phillips H7), Replaced all 3 rubber muffler brackets and pigtail for left side fog light bulb
83,000 Replaced tires with Yokohoma Advan S4 215/45/17
83,000 Replaced BBS wheel center caps on all wheels
85,477 Put in new Ford Motorcraft OEM spark plugs
85,477 Replaced drivers side window regulator and motor
85,477 Replaced windshield wiper motor and linkage
85,477 Replaced left hand turn signal assembly
85,477 4 wheel alignment
85,477 Replaced positive battery cable assembly
85,477 Replaced starter and solenoid
85,477 Flushed transmission
85,477 Flushed cooling system
85,477 Replaced cabin filter
EXTERIOR PICS:
