I'd much rather never seen that car without a engine ever again.
any updates beans?
3L cover? For a full swap you don't use a 3L cover since it won't fit in the car with it. Still have to swap the timing cover for a full swap.
Come on Beans... Didn't I send you the picture before you even started?
I remember at least telling you to be careful of it!
I got the P/S pump back today All fixed! w000t. I'm cheap and poor now that i am laid off.
My work DID however call me today and said they would have some work for me tomorrow, so at least i can make a couple bucks. So depending on when i get home i should get started.
You swinging by Harrry?
your cables are obviously fubarred. check em out. glad to hear its alive!!! im so proud of my little adam!
They are snugCheck the cable ends first. Sounds like your bushing is shot.
How do i go about adjusting them?adjust your cables and you should be ready to roll!
Well Ford makes a tool to hold your shifter in the very center of Neutral. If you don't have this though, you can have somebody hold it as close to center as possible. Then you pop the cable end off of the shift tower and push the orange button in. Make sure the tranny itself is in neutral (Black Pendulum straight up and down) and then slide the cable end onto the shift cable itself until it lines up perfectly with the pin on the shift tower. Push it on to the tower and then release the orange button to allow the teeth to hold that position.
