Quicksight
I've posted a nice long update twice now but it won't load so I'm done typing out a long post and then it being deleted.
Wouldn't bother with the oil "cooler" not worth it even if it was safe.
May I ask why?
did you check, 'remember me' ?
The stock oil cooler is actually designed to heat the oil when cold and cool when hot. The OEM cooler won't scrub heat from the oil as efficiently as an air cooled system.
So; if you have a turbo, it is not suitable but if you have a stock motor, it will maintain oil temps between rough guidelines, as it was designed to do.
This is why some FI guys don't rate them. ...G.
these threads that either
show no progress, take more than a year or never get finished dismay me.
I read here how it can be done start to finish in under two weeks.
The thing I like about this 3L swap thread is that this guy is making progress
I am considering doing a port match 3L swap and these threads that either
We all know how cumbersome stooping int he middle of these things and
starting back up can be. Seems straightforward enough, pull engine/trans
acquire 04-05 Taurus 3L install plates grind ports cut off alt tabs grind motor mount
re-install drive off with a smile
Right?
Didn't know that. I'm running turbo, and i've always had the stock oil cooler.
Well last night I wasn't up too late last night, 11:30 is when I stopped working on porting. I got a lot of porting done last night, me and my brother were both at it, him with a high speed air tool, ans me with a powerful handheld drill with a cord. We have about 30% more to do on that side, the other side is done, sorry about all the commas LOL. Today my goal is to pit the tranny on, and check out the alternator bracket. I'll port more tomorrow cause I'll need a new burr from the store, it's closed today. Hopefully my car will be back in my car and halfway finished by Monday night.
