elraido
I kant speel
just be sure to tell us where you put the switch so we can steal your car later.
makes sense. ok, i'm gonna do it in the morning, can't wait!You can hold your high beams on and turn the key it will start or you can hold your key at start and pull your high beams till it starts, your choice....
Do a how-to:
Or take massive pictures I wanna know how to do this!
Thats like a SIX Dollar Alarm System with basically no extra wires making things messy!
- Amyn
i like to do everything clean. i could just pull back the wire cover, but taps are prettierWire taps.... BAH...
lol taps are prettier. Taps are a fire hazard!
Do a how to? I just told you what to do. What more do you really need?
I don't think a capacitor would be able to do that... but then again... I could be very wrong.... would be pretty funny though, good way to protect yourself if it worked...
Other than that... RawBurt your starter wire is Gray/White at the ignition harness, bypass that with a switch and no one will be able to start your car....
These wire colors area all found at the ignition harness:
Ignition = Green
Accessory = Yellow
Starter = Gray/White
+12 Volts = Red
Be sure to test your wires 1st before you do anything.... Make sure these wire colors are correct before you go around cutting and bypassing things...
MULTIMETER MULTIMETER MULTIMETER MULTIMETER RA RA RA!!!
Why didn't you just buy the replacement transmitter for it then.... :shrug:
Oh and I listed the wire colors for you as well there if you read through....
you could hook up your RS status wire to the relay as well it would slightly more complicated.
It won't burn out the bulbs its just normal use.
You have to hold down the highbeams the whole time until its started
Does the bright switch have to be held in just to start cranking or does it have to be held on until the engine starts? I know the power (headlight switch) has to be on in order to close the circuit in the relay for the starter to be connected. I'm wondering if the switch has to be held on until the engine starts, will it shorten the life of my high beam bulbs.
BTW Steeda, this is one heck of an idea as long as it doesn't burn out my Silverstars. It sure beats this: http://www.jcwhitney.com/autoparts/...01&sku=MY23035G&searchbtn.x=13&searchbtn.y=13
Just thought of something (DUH), this is going to kill my remote starter. Crap!
