fordsvt98
Nevermind, other obligations, I can't go thru with this purchase...Please remove me from the list.
I'd be in, but I have a quick question first. Will these work on a Cougar?
Nathan
Copy this over to NECO for a Group Buy. That should get you 30+ no problem.
Hello Everyone,
I want to clear up some confusion on the difference in our QuickLIFT kits:
base QuickLIFT kit features black gas springs with silver Zinc plated brackets and hardware. 2 year warranty.
QuickLIFT PLUS Our latest release, a cross between our base QuickLIFT system and our QuickLIFT ELITE. All black components, including: the QuickLIFT black e-coated gas springs, black shafts, black ball-stud end fittings & black powder-coated brackets (from the ELITE system) along with the best mounting hardware. 2 year warranty. This kit isn't available for the Contour, since we are using ball studs for the mounting hardware.
For those who want the best money can buy - QuickLIFT ELITE. Includes the ultimate 316L Stainless Steel gas springs, black powder-coated brackets and the best mounting hardware. 4 year warranty.
All kits function the same and use the same force gas springs. For those of you with Carbon fiber hoods, we do have lower force gas springs we can use in your kit.
Regards,
Andreas
Owner/Partner
Redline Tuning LLC
Regards,
Andreas
Owner/Partner
Redline Tuning LLC
Regards,
Andreas
__________________
2002 CD Silver SVT Focus
1998.5 Toredor Red SVT Contour
1998 Triple Black SVT Cobra Vert
www.redlinetuning.com
The biggest 99-02 Cougar site. The car is almost identical to the Contour, so there are a lot of common users on both sites.Whats NECO?
bump whats going on?
How difficult are these things to install? Is it a direct bolt-on, or do I need to do some drilling, adjusting, etc. Depending on how simple the install is, I might be in.
For those with Carbon Fiber hoods, you can order either the base QuickLIFT kit or the Elite QuickLIFT kit and if you specifiy that you have a Carbon Fiber hood we will substitute the gas springs with lower force, either Stainless steel or black depending on what kit you ordered.
Regards,
Andreas
