KyleQ
I have the engine supported from below and above so it's good to go.
Not going to work - I wouldn't work anywhere near an engine support from below when removing the transmission. It doesn't gently slide off - you will have to pry and shake it off...
Once you remove the transmission the only place you will be able to support the motor is the oil pan - thinking the motor won't lean or rock when you remove the mounts is crazy.
