YOOOO
SO?! I'm gettin 9s sucka!
yeah but with what a 205 tire?! hahaha <3
Just special ordered these. Team Dynamics Pro Race 3's in silver. 17x7, +38 offset with a hubcentric bore
Glad you didnt get my esm 004s
Why did you choose those specs, may I ask? Especially a custom ordered wheel. You can go wider and have a more flattering offset. Im curious thats all.
Actually, one thing you couldn't customize was the diameter and width. 17x7 was the biggest you could get. I would have liked a 17x8 yes, but ultimately either way I'd run a 225/45 tire so the 17x7 works. I think a +38 will sit pretty nice without needing a spacer. I plan on running an ultra sticky compound (which typically run wide) and autocrossing on these, so fender clearance was important. As it is, I know I'm going to need a fender roll and I didn't want to have to do any more work than that. For shows and rolling rexxdoggy style, I already have a set of spacers I can throw on that'll make them sit almost perfectly flush.
Here you go... I photo chopped a wheel on your car as you requested. :laugh:
you will need to roll the rear to make it fit, you're right. I have 7J with +40 and it's cutting it close in the rear. My sidewall lettering is all gone. And I don't have a 225 tire. So the rear will need to be taken care of. The fronts should be fine, though.
I dig them...looks good!
