Lt_hailBob
No, it would be pressurized because the amount of air entering the box would be greater than that leaving the box.
What do you mean by catch? the Scoop?
curious...why doesn't anyone try an external point..ie hood scoop, or any other place other than a couple inches from a 200+ degree engine?? am i missing something or is it just that people don't wanna f-up their hood? i am thinking about fabricating my own hood scoop simplily for the cooler air and the ram-air effect. please if i'm wrong or fix'n to f-up my car let me know how and why!
no matter how hard you try your not going to get a ram air effect, at least not till hit well over what the contour will top out at (somewhere around 400MPH is the number thats stuck in my head). thats not to say that the cooler air from the scoop wont be beneficial but you certainly wont be pressurizing the intake system.
by the time you spend the time and money making it all work so that the engine doesnt suck in any water and make the hood look good, you definitely could have just run a CAI into the fender.ok, i think i know what you're say'n, but do you think this project would be worth the trouble?
NPG cold air intake. also if your really worried about it then you can install one of those AEM water bypass valves under the hood.
thats not how bypass valves work LT. they work via suction. they'll only open when the filter is submerged to the point were no air come's in creating the suction which makes them open. they're spring loaded.
no but that big puddle you couldnt avoid that just soaked the filter could end up being bad.Then its next to worthless... I have no intention of fording rivers in my CSVT
