striker2
Official CEG Vendor
i just need to check tire pressures and pack up and im ready to go.
He is basically saying that if you tried to put 318 equal corners in 11 miles, each corner would be 183ft apart with an entrance and exit angle of 60 degrees and have a radius of 29ft.Check this out, straight from the official Dragon site, anyone know what this guy is saying....really:shrug: Its too much for me to understand...
Dear DragonHeads
Had the opportunity last Saturday to cruise out your way and partake in the unique challenges of "the Dragon's Tail". Couldn't get my car out of second gear, so I thought ... "this is pretty tight." Having a fondness for juggling numbers I tried to put "318 corners in 11 miles" into an easily understood format - the simple average. Granted I took broad liberties in standardizing corner geometry, but I think the results are interesting.
My idealized corner geometry is very simple:
1 - turn Entrance is straight of x distance
2 - turn Radius is constant - also of x distance
3 - turn Exit is straight - again of x distance
Using these "optimized" arbitrary proportions,
an "Average Dragon's Tail Corner" would be defined as follows:
1 - turn Entrance - 61 feet
2 - turn Radius - a 120 degree arc of constant 29 foot radius,
total radius length - 61 feet
3 - turn Exit - 61 feet
4 - the turn Entrance and turn Exit legs would be at a 60 degree
angle to each other
5 - Average Apex-to-Apex distance - 183 feet
6 - Straight line distance from Start to Finish of the 11 convoluted
miles - 6.7 miles
So, if the Dragons' Tail were "standardized", you would have
318 corners 183 feet apart, each with an Entrance/Exit angle of 60 degrees
and a corner radius of 29 feet.
THAT IS TIGHT.
WOW! :shocked: Devils triangle looks SWEET!!! :drool:
Still time for you you know, we're coming straight down I-75 Thursday morning and we've got room in the cabins![]()
Ill make it one of these times, Im running low on vacation time this year though. It is on my 'to do' list though.
You could take Friday off and come on down, there's room for you and its cheap, $10.00 a night cheapHow far is it for you?
not sure on the distance...I am about 6 hours from Bristol, TN if its anywhere near there. I would probably be able to take 77 just about the whole way.
71 to 75 is a lot faster.not sure on the distance...I am about 6 hours from Bristol, TN if its anywhere near there. I would probably be able to take 77 just about the whole way.
http://maps.google.com/maps?f=d&sou...-81.820226&sspn=0.128569,0.308647&ie=UTF8&z=6
I know you guys have seen this while heading towards Deals Gap while on 129, it runs near that huge pipeline and I thought it might make for a great group shot, although there's a limit as to how many people can go onto the bridge itself:shocked:
What do you guys think, just to have something different for this years trip!
