alright guys so I'm getting started on my assembly of the engine today and I have a quick question. I had my heads resurfaced but I never had the deck of the block done because I left the internals in it. Is there anything I should do like polish it up or anything before I mount the heads?
Alright I'll do that thanks. I already have the head bolts and i'll go rent a tap. Also, I'm not a paint expert so I need some help with that. I'm painting the valve covers, UIM, and IMRC box. My question is do I just need to clean them really well and paint them or do I need to hit them with sand paper? and what kind of paint should I use?
alright cool thanks guys. and I did use a chase not a tap thats what I meant. Ok so I ran into a problem when I lined the head gaskets up to the block there were some coolant passages in the block that are blocked off on the gasket. any thoughts? I'm gonna start searching
I got the cams and chains on last night and that is a pain bank 1 sucks. To make sure everything was alligned properly I rotated the engine to make sure nothing hit and everything was good. I did notice something that might be a problem though. As I rotated the engine about every revolution, the chain on bank one would lose tension agains the guide and it wouldn't regain tension for a bout 45 degrees of rotation. any ideas?
Ok I'll give this a shot. I'm sure I'll be corrected if I'm wrong.
1. You can use the 3L water pump with all the 2.5 cooling lines. I think you'll want to use the metal coolant outlet from the 2.5 which is next to the pump on the right with the sensor plug. I needed to swap this piece from the Escape engine I used, but I'm not sure if the Taurus and Escape have the same setup. The Escape had a plastic piece. I know the Escape 3L pump looked different but the Contour lines hooked right up.
2. This one I'm not totally clear on but I think the green is the EGR and the red is the fuel pressure regulator?. I guess I would try and repair the vac lines, new ones might be hard to find. I had to use some hose to replace some vac lines but it looks like it will work just fine.
3. You can swap this over to the 3L. There should be a plate on the 3L that covers where this goes. It's for the PCV system on the Contour.
Nice work and good luck. I hope this helps.
Your correct. Green is for the EGR valve and red is the fuel pressure regulator
