Brian-
I am only talking about the injector harness. As for the 95 harness, that I dont know. The IMRC connector comes off the injector harness, so that would be different. You would need to check the pinouts at the 3 connectors near cylinder 1 to see if the rest of the wires match up. I would guess it wouldnt just be a plug and play.
As for the 02 cougar on the 95, I dont see how that would even come close without a ton of modification. The 02 will be returnless, so on top of EV6 connectors for the injectors, you also have a FP sensor on the fuel rail. I would think the pinouts for the 3 connectors would be very different. Why wouldn't you have used a return style harness?
When I repaired my harnesses, I used an E1 injector harness out of the box, just plugged it in. When i did the ECU harness, I took the E1 harness, unwrapped it, and then took the wires out of the E0 harness that were bad and put wires from the E1 harness in there place. Some key differences I noticed, the Crank and Cam sensors on the E0 were shielded pair, small gauge wire that was in a sheath with stranded shield, but the E1 only had this on the crank sensor. The cam was still shielded, but it was 2 wires that had a third wrapping around them, all insulated.
