jlm98silversvt
Where do I buy this kit. I searched, with no luck.
All I see is the WilWood brakes not the Baer
$2000-2200 later, you're the only contour owner with a 6-piston setup!
The only thing I am afraid about is due to what i have heard.
Losing all your brake fluid can cause the brake booster or master cylinder to break, and it must be changed at that point! Now if that is not gonna happen per say
when I remove the rubber lines to put on the SS braided ones all the brake fluid will come out.... Is there a way to stop this or is this the way to just do it?
- amyn
http://www.tceperformanceproducts.com/cgi-bin/brakes/cginews.pl?record=7
you can still order them thru tce
i had to bleed mine. nuthn happened to my master cylinder. just an old ceger wife's tale. hehe. just make sure u follow the bleeding instructions to the letter. they come with the kit.
Beans Oh DAMN Joe! I didn't know you had 6 piston Wilwoods! holy crap those are MASSIVE!!!!!
Would those clear 17"s? Its hard to tell =o Does anyone sell 6 piston kit for the tour?
I bought the Willies from a guy in CA that had them on his torched SVT.
