hectik1
The Hispanic Hellion
Mine is shorter......NAH!:laugh:Yeah? Well, my hair is longer then everyones! NAH! :crazy:
Mine is shorter......:laugh:
Come over here Steve.....I will show you.:laugh::shrug:
what is this Gibsons ya'll speak of??????
Who are all of you fruit loops anyway????
If I can't take my attitude and ego I ain't going!!!!!!
:shrug:
Think Lori's Duratec in the Coug is trying to go south. Got some rockin drivetrain noise. Believe it is from the head, hope it is not below it. Lots of clatter in low and mid rpm not much in high under load... :nonono:
May grab the head from it if it is indeed messed upI've got an 98 SE motor & newer trans I'm about to pull out & replace w/ 3L stuff! Motor has about 110K on it but its auto so no real redline pulls, & it is the wifes car so it hasn't been weekend raced. I haven't even started gathering stuff yet since I just did the 3L on my car but this engine doesn't use oil or anything, maybe you can convince me to go ahead & pull it out!
Man I hope it is only injectors...it is seeming like it is valvetrain noise....Lori says c'mon. And that is for anyone else too!!! We will be tapped as far as cash this weekend...love my bills, so the possiblity of getting all the fixings to fix the car are not too good...but the following weekend I will be good.Have you pulled the Upper and Lower intakes and cleaned all the passages behind the TB to the EGR? If not, that would be the very first thing I would do. Seriously!
Mine did this for a little while and I had to do the above, plus run several tanks of fuel injector cleaner through it. It could be bad enough that you might have to take it somewhere to have to fuel injectors cleaned, but then again, you can get this stuff over the counter anyway.... so.... there's a lot of options to go through before you start pulling heads man.
Give me a holla if you might need some help. Maybe we can work something to where we can make a trip over there one Saturday that Kim isn't working or sumtin'
Oh don't worry...do the words babying something, mean anything to you??? Guys.....we are really bummed by this. We have owned the car for like a year and now this....man, lemmie tell you, if I can afford it and get it R&R'd at R&R speed shop, it will get ported and polished...GRRRRRRRRJust be careful when removing the two hard vacuum lines from the UIM. They're $45 each from Ford, 3 years ago. :blackeye:
'Babying' them don't work. I had to pop 'em out with a pencil from inside the UIM. Take off the TB and tap a pencil into the lines' opening to push them out. That's how I kept from breaking both.
