Found the problem
Found the problem
So yea, I found out the problem with my car...and I feel like a real idiot. I finally got someone over to start the car so I could stick my head under the hood and listen around to see if I could hear a vaccum leak...and oh my God was there a leak. I took off the upper Plenum today and used a light and sat it between my heads and looked in the intake ports for signs of light. On the Right head (looking from the tranny to engine; firewall side) the center port lit up like Christmas. It turns out my JBWELD injector blockage gave way, and I had a gaping hole! I feel like an idiot for not seeing it before. I mean, how can you miss a dime sized hole? Anyways...I have to take off the uim, and check the prt for debris, and I also think I'm going to drop the y-pipe and check my cat for anything.
Anyone have any suggestions for fixing the hole? Please don't say removing the head and getting it welded. I should have done that in the first place, but I know several people have used the JBWELD and had no problems. So I decided to use that and save time.
