DAMN!! how could i have not figured that out!
Especially since we told you 2 years ago.DAM!! how could i have not figured that out!
http://www.contour.org/ubbthreads/s...er=1158370&page=&view=&sb=5&o=&fpart=all&vc=1
HAHAHA!!! dam!! forgot about that!!
that was when i replaced the crank pulley!!
dam tony!!!!!!!!! hahaha!
Do you have a picture?so anyway what is that black little box that is directly next to power steering pump and under the UIM/LIM ??...)
so anyway what is that black little box that is directly next to power steering pump and under the UIM/LIM ?? is that the PCV air breather box??
( fyi - i researched the old post i did too)
what is it??
Good luck changing that gasket. One of the heads has to be removed for it to fit between the heads. With the UIM and LIM off you might be able to sneak the gasket back under while holding the breather up with a magnet.my oil leak is coming from behind that piece.
