Hello guys.
To all of you experts..
Is it bad to run a valve cover small filter?(valve cover breather) I have the original hose connected to a small k&n filter which bypasses the air intake. I'm trying to figure out if somehow affects the PCV system and if this is why excessive oil consumption takes place..More blow-by and that sort of a thing..
In the stock air box , the valve cover hose plugs into the air box under the filter.
Also wondering if the air being pushed out from the valve cover gets sucked with the air from the CAI will reduce blowby..
If nobody knows , I might have to figure out a way to run it back into my CAI before the filter or have an oil collector in the hose(noticed small amount of oil in the little filter..don't want to get that back into the engine) before it goes back into the intake(after filter)
Thanks for any ideas
