hypnotic3650
is it true I need the zetec speedo gear? I have read that in several places but it went on with just as much force as it came off of the old one...i cant see why it would need changed
well, its not the taking it all apart thats an issue for me, but the fact of having all the correct parts on hand ahead of time so there isn't a shipping delay issue with the functionality of the car.
Yes, you need a zetec speedo gear. The Quaife was made for the Focus and it happens to work in our trans but you need the zetec speedo gear which is used in the Focus and 4cyl Contours. I beleive it was discontinued but I think BAT is selling them.
An MTX-75 speedo gear is an MTX-75 speedo gear. They did not change between Zetec and Duratec. This is false information that's been floating around the forums for years.
if u are useing ur original ring gear of the diff the final drive will not chnage even if u change ur final drive with a final drive kit that comes with an output shaft and a new ring gear for the diff ur cv shaft are still doing the same rotations and thus the spedo gear will not be afected only thing a final drive upgrade will give u is higer top speed but the diff will still spin like it did and each rotation of the diff gives u a rotation of the cv shaft and ur spedo will still read proper no matter what kinda final drive u get ....... only thing to afect ur spedo acurecy is tire size
