Garrett76zt
Hey guys, i actually just purchased this car today and I'm in the process of cleaning it up and working through some "hiccups" the original owner obviously had. The car is a '98 CSVT and the 3L swap was already done with what I'm told is an '07 Escape 3L. I've been doing lots of research on the 3L swap over the past several months but still have questions regarding the one I picked up today.
Right now the car is barely driveable when cold. It bucks and hesitates really badly. As it warms up it gets progressively better. When fully warm it feels pretty normal, acceleration wise, if at half throttle or less but still hesitates a good bit when going full throttle.
My obvious concerns are with the current setup TB to MAF. Right now there is nothing before the MAF inlet. 2 vacuum ports on the intake tube have been plugged and two ports on the UIM have been plugged. I'm not sure what the deal is with the throttle body. It seems obvious that this is not the correct throttle body and throttle cable setup for this swap. Can you help me identify what it is and what I need to change it to? Also unsure if the MAF is the correct one or not? Given the symptoms I suspect TB/TPS, MAF, and vacuum leaks.
Please take a look at these pics and let me know any red flags you guys see.
Engine bay today when I purchased the car, drove it about 60 miles this way.
Closeup of intake
Throttle Body closeups - top right bolt hole does not lineup with UIM hence the previous owners "fix".
Bottom side of the UIM, top two ports are blocked off and bottom two ports go to brake booster and Fuel pressure regulator
Intake tube closeup - these two ports are blocked off
Sensor and PCV
MAF closeup
There are also a few connectors in the engine bay that are currently not plugged in. This one is just to the right of the UIM
These three are between the rear valve cover and the firewall. Two of them look like a TPS plug and a IACV plug, not sure about the other one. There are separate plugs already plugged into the IACV and TPS and the ones pictured do not fit. Any ideas whats going on here?
Thanks for any help you can give me!
Closeup of intake
Sensor and PCV
MAF closeup
