imstock
+1 for the scoop. We dont all want to drive around in Eggplant. (although I do love it )
inspiration sure does suck doesn't it get over itI hate it when people post that car.
only problem is, i couldnt sand the scoop down to make it fit cause i wouldve had to cut off the screws. so im thinking about making a mold out of resin and gluing it in and then putting more fiberglass and resin over top. any better ideas?
well the thing is, the screws are on the scoop, not just holes. so to cut down the scoop id have to cut off the screws too.Kerfs. You cut multiple straight cuts at 90 degrees to the edge. Then it will curve to fit the surface. Then you glass over your cuts on the outside. Remove scoop. Glass the inside, smooth and paint. You might have to elongate your holes just a tad. Because once the scoop is curved, it will move the bolts inward some due to the radius of the curve.
Here's what I'm talking about, done with wood. Same concept.
the hood was one of the mainest parts IMO. mechanically the car is 100% and i had to paint the hood either way. had some scratches and stone chips. so i figured i better just throw the scoop on itHahaha, just caught this.....
Anywho, adding the scoop was something you just didn't need to worry about just yet. You should focus on the main parts of the car first. Progress is good though.
No to the fiberglass. Bondo might be a better plan but it could easliy crack from any flex in the hood..
You should cut a hole for the hood scoop. The air would be directed right at the UIM which would keep it cool? That or just keep the underhood temps down in general.
hate to jack your thread but just curious...what bumper was that on the car posted on the second page with the multitude of colors?
