KyleQ
Looking forward to that template! I'll head to Menards and get the needed bolts and plexiglass.
also the 2k tower the shifter sits in is all plastic also iirc ...
please post side-by side pictures of stock vs. this when you take it back out so we can confirm 100% that this is a steeda.
It is Plastic
*pic*
It is Plastic
Has anyone bent one of these to match the bend of the stock shifter?
Bugzuki you supply the riser plates I'll supply you the bolts to send with them lol.
why :shrug: that defetes the purpose of the shifter ...
How would that defeat the purpose of the shifter???
All it would do is move the knob back to the stock position...
have you guys with the steeda shifter had problems reaching it?
do you see the slots in the red circle? you make them bigger. also if you cut out the template and put it up to the shift tower you will see how it lines up perfectly with the sides and shapes of the shift tower. you will see what I'm talking about when you do it. your going to need to remove the center console and the cigarette lighter/cup holder console to see what your doing.does any one have a pic of ewhat you need to grind off? that would help me out a lil bit
