TourEnvy
Use the gradient tool in PS, similar to the RAINBOW one. Dont worry you can substitue the colors. Try using a base coat in dark purple then use the laso for the area of the car you want to shift in color. use the gradient tool in that area (including the base color at the end to blend with the meeting panels).
You can also try using the radiating gradient tool with transparent and a high light color to do specific areas. Best option for this is to create it on a sperate layer, color in the center and transparent on the outside. then use the marque selection tool to take what you want. Keep it selected so you can transform it until is looks good.
:crazy: :crazy: :crazy: Good luck!
