95pgt-t
irish spring soap is another mice deterent. take a few bar's and break them up and place them in and around your car.
ALL of the air coming into the cabin comes through that filter. So pretty much everything you breath inside the car with the windows up comes through there.
you can also use dryer sheets.
put them all over the place in the car, the trunk and even the engine bay.
they keep the mice away and they help make the interior smell nice when you take it out of storage
I may be asking something common and i didn't search for a solution for this, BUT i replaced my cabin air filter like i want to say four months ago, and even then i turn on the heat to the windshield setting and when it pumps out air, at first it smells pretty bad.
Also, this happens when i turned on the A/C here and there this past 2007 summer....so, am i missing to clean the whole piping on this and find stuff that shouldn't be there thus causing this problem?
What do you folks suggest?
I can probably change the filter again, just to be safe, the weird thing is that i mentioned before is that the smell was there even after the new one went in...
Thanks for all suggestions!
As I had no idea when mine was last changed, so I decided to install a new one.
It looks like it had never been replaced! :nonono: It even had some mold on it.
and I was breathing the air passing through that filter.
Getting off subject, but I noticed you have a F-150 due to the reflection of your wheel. What year?
WOW :shocked:
This guy should work for the FBI.
It is a 2002.
