blu_fuz
New Member Classroom vulture
I didn't notice a difference in my '95.....
when I drove my SVT back to back with my SE before the 3L I felt that the SVT rev'd up fast and was smoother but the se felt like it had more torque.
Yeah - mine revs way fast with an 8lb flywheel, sure makes rev matching VERY easy.
8 lbs?!?! Good Lord! I just got my new parts in the mail today. The kit and flywheel together was 32 lbs. :laugh:
I wonder if they changed the metal they make the clutch out of or something for it to start doing this.
I think this is the one LivinSVT told me to go with if went with the clutchnet
http://www.clutchnet.com/product.php?productid=10343&cat=0&page=1
is that the one he is using in his car? Im not sure which one I want to go with. I also plan to get a matching pressure plate since mine shows whitness marks on the fingers. So I am not going to take any chances reusing it.
I think this is the one TRicker went with. He says it similar to the Spec 3+ but is a lot less noisy since the splines line up exactly as they should.
http://www.clutchnet.com/product.php?productid=17494&cat=161&page=1
No, he has a spec 3+ as well. He said so far he hasn't had any problems...knock on wood!
I would probably go with the one elraido posted. Sprung hub "Fiber Carbon" yellow disc. Solid hub is designed more for just racing. It would be very on/off. There wouldn't be any give in the disc.I noticed on Clutchnet's website that you can either get the solid hub or a spring hub. They have a few different selections but I just dunno what one I would want. They have 2 carbon metallic ones but the only difference I see in them is a part number. Both are solid hubs so no spring failure.
I think TRicker might have the solid hub "red" disc, I'm not 100% sure on that though.
Wow, I just caught this thread. That really sucks Brian! What was the mileage on your clutch? IIIRC, it just went in with the 3L or turbo right?
I'm getting close to needing a replacement clutch on my SVT, but I don't know what to go with anymore. I have a SPEC Stage 1 that has just under 60k miles on it and it's never given me a problem. Since I probably won't be doing forced induction anytime soon, I'm tempted to just go back to a stock SVT clutch, although the 3L might be a little too much for it. onder:
