TRicker
make sure everything is CLEAN CLEAN CLEAN when doing your clutch swap. that dust these clutches make is my worst nightmare right now. even with the clutchnet disc....
yeah i had a quaiffe installed as well as stage 2 axles, but i dont plan on abusing too much.
I almost puked when I looked at the bellhousing on my transmission. Lots of clutch dust + a lot of brake fluid shaken and spun = one giant gooey mess. I scrapped almost 3/8" of crap out of the bellhousing before I installed the new clutch. The flywheel and PP got a healthy cleaning with lacquer thinner before it went together - all seems well so far with ~ 250 miles on the clutch.
Is the dust having a negative affect on the performance or what? Anything to look out for?
Its always made the famous "clutch chatter" only when disengaged. Should i be worried?
So i pulled her out of the garage & saw some brake fluid on the ground. So i'm guessing my TOB is done or on its way out. I'll post where the leak is coming from soon as i find it.
Hopefully it is just a loose hose! (outside of the tranny)
Yay!!!!!!!!!!!!!!!!!!!!!!
:laugh:
Thx. ...My sentiments as well. It was about time i changed my fluid anyway. It was a bit dark in colour. I'm pretty sure i've got this right: But when the main reservoir is empty, to push all the air out, i need to bleed in this order; Rt Rear - Lt Rear - Rt Front - Lt Front - Clutch. Correct?
I ask cuz i know i've heard some cars having to bleed the reservoir itself...
My Spec 3+ is still working perfect... KNOCK ON WOOD. :laugh:
onder:
Well then it just might last forever :laugh:You have to drive your car in order for it to fail!!!!!
So I'm going to look at the car again tomorrow (I've been refusing to go into the garage) - I've got everything pulled (had to hack up my pass side floor to get the rear subframe bolt out) except the bolts holding the transmission to the motor. The shift tower is stuck in the transmission so I'm pulling it so I can split the case and physically move the shift fork to get it back in nuetral so I can weld the •••• out of the shift tower to ensure it doesn't happen again. I'm not even going to put the bolt back in it, I've replaced so many of these it is just stupid to put it in again.
The car isn't that far off the ground - so I'm going to raise it higher in hopes it lets me get more room. New clutch is on the way - hopefully nothing else is trashed in there when I get it apart.
I am correct that I can pop the bellhousing off and get inside and move the shift forks, correct? I've had it apart for the Torsen, never tried moving the gears though...
Hopefully this one doesn't blow up, I guess nobody could beat on the car as hard as I could, so I shouldn't worry...
Run a focus tower, or later cougar tower. Much stronger.
Sorry about the clutch.
