svtcontour666
i thought you guys would be happy guess not?:crazy::crazy::crazy::crazy:
uhm also i heard the 04 tarus motOR WAS easyer to put in because of fuel rail and upper intake manifold fabs that would hae to be done instead i was just going to put my svt upper intake manifold on my 3.0 liter and also use the intake sytem from the svt 2.5 i already have now!
also i was going to use the svt cams for the 3.0 liter i have heard doing it this way was easyer and i will get alot more torque????
i can`t wait at all !!! i am also getting the quafe i believe is how it`s pronounced diff lsd !!! from a buddy of mine!!
...Have you done your research?:shrug:
its not a true LSD, true lsd's have plates, the quaife or torsen has gears.
Its actually an automatic torque biasing differential.
We will have no pitty on you if you got the 3L SOHC Vulcan Engine.
I wish 3.0L engine's were this cheap overhere in the uk and this readily available to. Wonder what it would cost to get one shiped over from here (usa) to the uk?
also i was going to use the svt cams for the 3.0 liter i have heard doing it this way was easyer and i will get alot more torque???? LOL.... ya right!
Forget that crap keep the 3L a 3L, adding SVT parts to it just causes problems and gives NO benefit. The 2.5L parts installed on it are smaller in port sizes, and most of all DON"T FIT properly. SVT cams, why the 3L's are better for the 3L. The 04 you got is better and larger than the 2.5L SVT and if you install it as a complete motor you'll be $$$'s ahead.
You are beyond SVT now do the research, and do it right, most importantly do it only once....
my 2 cents,
AF
