oh, forgot to ask, will the evap line from the taurus work on the contour?
I burned a hole in the contour one and it has tape on it. it works fine, but looks janky if you really look down in there.
also, the coolant pipe between the heads is different on the 04, can I use it? or do I have to swap on the other one? I ask because I've seen them break and leave a disaster to remove from the front head.
and last but not least, I'm using the 02 valve coves and intakes to save time, so it looks like I have to get that black box out from the middle of the 02 and put were that filler plate is on the 04 for the pcv? is that very hard?
any other little nuances like that I need to know between the 04 and the 02?
thanks guys
why wouldn't you just use the whole 04 engine? wiring up the cop doesnt take much time or cost anything, that way you can keep the revised pcv. you might as well use the 04 intake as well. I have always used the 2.5 coolant x over in the in my 04-05 engines.
