KAOS_3.0
NPG fuel block with the stock 02 fuel rail.
MAF is 2.5 SE
TB is un-modded 02 3.0 with fab'd up bracket.
injectors are the grey taurus ones
tune is an NPG base tune from joey
I know the 2.5 one isnt right, but it is sealed up to the openings right, I filled the empty space around the inlet and outlet ports on the 2.5 IAC with bondo, cut that flat with a razor, then permatex'd the original 2.5 gasket to that surface, then bolted it on. it's not leaking, it's just not right, it's running open too often. that or it's on backwards, idk. I will say the engine tends to hang at a higher RPM when I first let off the throttle, which isn't right, and seems IAC related.
how does making a spacer for the 05 IAC so the cylinderical part of it will clear the 02 uim sound? will the 05 one work right?
I have also wondered, since the IAC works a lot like a speaker, if by swapping the wires (reversing the phase), one could be mounted 180 degrees from it's intended orientation? just a thought I had. IDK
MAF is 2.5 SE
