KyleQ
I've pulled 5 transmissions out of the drivers side wheel well - TRicker and I pulled my engine to install my clutch and headers - but the reasoning there is obvious.
You do not need to remove the radiator - there is a hole in each peg that goes through the core support. Put a piece of welding wire or a cut up coat hanger in there and it will hold up the radiator.
Disconnect the steering from under the dash - 1 bolt.
Don't be lazy - support the engine with an engine puller, big safety deal as when you remove the trans from the car and install it again you are going to have to shake and pry it a little bit.. a jack will fail at this point.
Drain transmission - pulling the cv shafts will also do this for you :laugh:
Pull the drivers side strut with the cv in tact and set it aside - wire up the caliper through the hole where the strut mounted to the tower.
Pull the passenger side strut with the cv in tact - wire the caliper up the same. Put cv in vise and using a punch remove the intermediate shaft from the cv so the installation is much easier.
Remove the obvious stuff - intake tube, battery, battery box, disconnect the exhaust from the y-pipe, hydro clutch line, grounds, front and rear roll resistors, etc etc. There is an A/C canister on the front of the subframe - unbolt that and let it hang.
Support the engine with a puller - remove the passenger side motor/trans mount, remove shift tower, shift cables, unplug wheel speed sensor and starter. Remove the front subframe bolts - looser the rears until there is only a few thread still engaged in the nuts. Push down on the front of the subframe until it comes close to contacting the floor (if not all the way - more space the better)
Put some foam or cardboard under the engine and start removing trans bolts. Put hand in shift tower hole and starter hole and start working the trans off the motor - may help to have a buddy pry gently on the trans with a prybar/screwdriver.
Once the transmission is removed from the engine set it down - it will rest of the floor and subframe. Have a buddy push down on the subframe while you pull the transmission out the driver's side opening. It will be a little tricky - but it almost looks like the A/C lines were routed in a way so the trans will clear. It will take awhile - take your time and don't damage the brake line where it comes off the front fender apron. I've done this quite a few times and I can have the transmission out of the car in under 45 minutes - that includes removing all of the bolts (and having fun with the front split nut one) pulling the trans off the motor and wrestling it out of the car.
My stage one lasted as long as yours did behind my full 3L - the torsen really shortened it's lifespan.
I'm sure I have missed a few things - but I almost find this job easy now... I've had my subframe down twice now - alignment still in tact...
