TRicker
well i changed my oil today......it only gave me back three quarts. and the car was off for about 2 hours before i changed it. it wasnt reading on the dipstick.
it doesnt leak oil, and i cant see any smoke at any time. i've got two ideas of where it could be going.....
1. into the antifreeze..... but that is fine as far as i know.
2. staying in the heads (clogged drainbacks from gunked up old conventional oil from the previous owner) i did run seafoam through it this oil change.
3. i'm running the taurus crankcase vent box with a "custom" tube going to the 2.5L PCV. someone said once that the PCV is built into the 2003 taurus' vent box and i would be running two PCV's in line if that is true. could this be giving me too much crankcase pressure causing the engine to burn oil...... (but like i said i never see any smoke) ?????
help! i don't know what the problem is....... i cant find a leak, i can't see/smell burning.....but it's not keeping oil!
thanks for the help boys and gal's i need a response fast i'm getting worried...
oh yeah and the specs......
2003 taurus block and heads, SVT cams, intakes. i kept the 2003 taurus oil pan on it. the gasket for that was untouched. all the other gaskets were replaced. like i said, it doesnt leak any fluids. i cant even see any excessive oil or grease buildup on the engine or any of the chassis. i'm at a total state of confusion. it must be burning oil or it's not draining back. the oil in it before made the inside of the engine a slight red in color....i'm guessing they used a cheap conventional oil on it....there were some sludge deposits in the heads when i had the valve covers off. anyways thanks for any insight you guys might have.
