warmonger
I'm interested in this If you can ship to the UK
Sure can! I have no problems shipping to UK, mainland Europe or Australia since you are paying shipping.
Will these front brakes work on my SE, I understand I'd have to convert my rears first?
the front kit will not work on the SE unless you have upgraded to SVT front brakes or can get the SVT caliper bracket
you do not need to convert the rears first to be able to convert the fronts, but if you do the fronts first and have good rotors you can put them on the rear and not have to buy new rotors for the back
now i'm confused, isn't this GB also including brackets and as far as i understood, u just change the brackets on an SE in order to upgrade to SVT's larger rotor. wouldn't this also apply to FSVT brakes(front), unless i'm just way off base here. I do have FSVT rims on my SE, so i don't have a fitment issue. :help:
you are correct, on the SE you change the caliper bracket to use the large SVT rotors. The bracket for the front in this kit takes the SVT front brakes from 278mm to 300mm, the SE comes with 260 mm front rotors ...
to use this kit you first need to have the SVT caliper bracket so you can fit the 278 mm rotors ...
the kit was designed for the SVT not the SE
also this kit doesn't replace the caliper bracket, it bolts to the bracket to move the caliper
My noob understanding is this:
I own a '99 Contour SVT.
With this setup:
The brackets will extend the clearance of the caliper from the middle to allow for a wider rotor.
The rear kit will allow me to place my EXISTING front rotors on the back (pending they are still in good condition) which will make the rear brakes capable of holding larger rotors than stock. If those fronts are no longer serviceable, I will just purchase a new set of front side rotors for the CSVT to place on my rear brakes.
The front kit will then allow larger rotors (which are commonly on the Focus SVT) to be placed in the front. Same reasoning - more clearance from the brackets.
With this setup:
If this was offered on Nautaulis Performance I'd be down, because I wont be able to afford this for at least a month.
I'm thinking about introducing it as a group buy now and then if the group buy is successful I'd introduce it as a regular Nautilus Performance product.
I am mistaken. So this kit moves my front rotors to the rear, and FSVT rotors to the front. Damn, thats awesome! Too bad I can't afford this right now, I'd love the bigger brakes. If this was offered on Nautaulis Performance I'd be down, because I wont be able to afford this for at least a month.
Also bear in mind that the FSVT rotors are not included. You get the kit from Nautilus Performance, and rotors elsewhere. From what I heard, people sourced their FSVT front rotors from
The price varies. Normally you see between $100 - $200. And they are heavy to ship. Some people (myself included) also do the braided brake lines at the same time.
- Ford OEM (BJenkins, Steve @ Tousley Ford, etc)
- Bendix (Stazi)
- BAT
- Ebay (cross your fingers)
also I believe warmonger commented that upgrading the front and rear will keep the stock braking bias and pedal feel, where as if you upgrade the front only you will obviously get some uneven brake bias .... If I am wrong I am sure he will correct me ...
