warmonger
Well it hit 224wHP/228wTQ rear wheels deactivated on the AWD but still turning all the transfer case hardware and driveshaft.
This is the third generation exhaust manifold with the wastegate vented to atmosphere, the stock intake system (filter and all) and the stock exhaust minus the vented wastegate.
Amazing how it was able to make more HP at the wheels than it came with at the crank on the SAME 10psi boost pressure with just the larger more efficient turbo!
I thought I should share and get any new comments and answer any questions.
Okay, if the image above does not work then you can go http://www.nautilusperformance.com and then click on the Volvo S40 links to see it.
