BurritaSVT
a rpm range that no matter what the engine vibrates hard causing any solid metal touching to resonate throught the contour body.
I have a hard vibration or bumping feeling that happens between 3000 rpms and 4000 rpms. This vibration can be felt and heard a little even in neutral. On the highway with a load it feels a slight bit harder but as soon as you let off the gas and push in the clutch its going. I have a DMD and I remember some people i think like Keyser or so who spun there DMD with high HP numbers. I do have a solid mount in the rear metal to metal and was wondering if the motor just resonates or it frequency range for shake is there. I eliminated rod knock because it would do it all the time and would be heard more than felt and would be louder at rpms. The noise or vibration dispates after 4000k I may go back to a rubber mount or change my DMD if it continues. I also had my engine completly balanced and if I understand correctly that would vibrate harder the faster it rotates. Just wondering to what people may think.
