UIM/LIM Rebuild Pics...In progress....
wchain
Hi Gang,
First, thanks to everyone for all the previous directions and write ups!
I Thought I would help others by sharing my UIM/LIM Rebuild Pics...
So I unbolted the upper half last night...
Here's the throttle body...
BLECH!
Here's the upper intake manifold....
Close up...
Lower Intake manifold (yet to come out)
Close up...
Chemtool is a wonderful product! I cleaned the upper last night, little scrubbing required, but soaking it removed a LOT of the residue!
More pics to come!
Nice pics my friend, but be sure to check the "How To's" on cleaning the UIM & LIM without removing them. You still use the B12 but suck it in through the two large manifold vacuum lines. The reports are that it works well.
Please post more pics as you proceed, and tell up about any observations, or methods that make the job go better.
And BTW Welcome to the site.....
Regards,
AF
Thanks Aussie,
I considered that, but it took 20 minutes to remove the UIM, so its not a big deal, plus, I really wonder what happens when you wash all that sludge down into the engine.
I'll post more pics tonight after I finish!
:cool:
The sludge just gets burned up no big deal, and yes the job is easy to do, but you have $50+ in gaskets (ford) vrs $12 for a can of B12. There is the advantage of doing it in place. Remember no reusing old gaskets, and there is a bolt sequence for removing and installing it that must be followed.
Looking forward to more pics.
AF
the on-car method works.. and works well.. as long as you realize where its intended place is in the maintenance ladder.
Its a preventative/small scale cleaner.
clean the UIM/LIM OFF the car, then do the on-car method every 12-15K miles or so to PROLONG the cleanliness. (it will NOT "keep it clean" nor "make it clean".. it just erodes SOME of the build up...)
If you do the on-car method to a car that's NEVER had the UIM/LIM off the car for a good cleaning, you won't notice a difference.
So.. OFF-car... initial clean.
ON-car, prolong the cleaning..
What he said.
What?! I hope your kidding :shrug:
nope, the LIM and UIM gaskets are of the type that can be re-used a few times but not indefinately. They are similar to the Taurus ones ... but remember those are built into the LIM and UIM ...
I wouldn't reuse ones that are more then 2 or 3 years old and have any sort of miles on them ...
Oh well, i could understand maybe a year old one, but i pulled mine off they where 100% original with 90k on them. Talk about owned :blackeye:
I still have yet to see a UIM/LIM as bad as my Mystique was.
Do keep in mind if you run a cleaner through the manifold you'll probably want to change your spark plugs right after because they will get nasty and some will foul. Of course the plugs are easiest to change when the manifold comes off so there you go.
Then an oil change:cool:
I went ahead and bought new upper and lower gaskets, IAC, EGR and TB gaskets.
Spent less than 50 dollars. Seriously, is it worth buttoning it all back together to find you have a re-used gasket leaking?
:nonono:
how do you remove the two vacuum hoses that run into the UIM on top of the plenum? I want to run some seafoam through the intake, but I don't want to break off the hoses.
If you look at the base of the hole there appears to be a collar around where it enters into the manifold. What that actually is, is a lock ring. Take a screw driver and hold that down (it is already down just keep it there), then pull up on the elbow. It will come out. You might pull up on it w/o holding the ring down and see how it works..... it will lift up about 1/16" or so.
When I first did this I thought what the heck am I holding down here nothing is moving..... But then the elbow released and out it came. Sometimes a little wd40 is needed to get it out.....
Of course as usual, I practiced on a jy car first......:laugh:
AF
awesome AF.....thanks...I pulled them out just to check how easy it was. LOL...What size tubing would you recommend putting in the holes in the plenum for the seafoam? Do both holes go to the same place, or is it advised to place the tubing in one hole, then move it to the next with the other half of can of seafoam? Also how would u hold open the secondaries when doing this so they can get some foam too???
Well what I did was to get those tubes from the JY and cut them off at 8 or 10" and then took them to the Home Depot and just fitted some tubing to them since they are different sizes. Got about 3' of each size and then connected them in place one at a time using about 1/2 the bottle in each hole. They go to different sections inside the plenum, so you want to use both holes. You need to have something to pinch it down to control the flow so you don't kill the engine when you do it. I used a "C" clamp for my control valve.
Hope this helps.
AF
I did think about that a bit and next time I will probably see if I can just disconnect them and open them a bit by hand I have extra clips now..... just thinking here......
This is the How to by Big Jim that I followed with a variation on the lines:
Cleaning intake manifolds without removing them
[SIZE=-2]Author: Big Jim
Applicable to: All vehicles, especially V6
Added: 11/12/2003
Updated: 11/12/2003
[/SIZE]
[SIZE=-1]
This document is also available in the following formats:
[/SIZE][SIZE=-1]None
[/SIZE]
[FONT=Verdana, Arial, Helvetica]I would strongly recommed cleaning the intake manifold chemically without taking the mainfold off the engine. It is much easier and there is less chance of having someting else go wrong while you have it apart.
Do it before you change the plugs. Change the oil afterwards.
Get a bottle of liquid pourable injector cleaner. The last time I did mine, I used Berryman's B12, but I have used BG, Red Line, and Techron. The cleaner is fed through the vacuum taps on the top of the intake manifold just behind the throttle body. To remove the vacuum line, hold the retaining collar with a small screwdriver while gently prying on the fitting to pull it out of the intake manifold. Remove one line at a time for cleaning.
Find some vacuum line just the right size to slip into the hole. You need about two or three feet. Slip one end into the vacuum hole and the other end into an open container of injector cleaner. Find a pair of Vice Grip pliers and pinch the hose shut. Start the engine and very gently twist the screw open on the Vice Grip to permit some liquid to flow. This part is tricky since it is really hard to meter the flow and if you get too much the engine will stall. It may help to hold the throttle open a little while feeding the cleaner through. When the bottle is about half gone, switch to the other vacuum port.
Next, clean the throttle body. You can use a little of the same cleaner you ran through the vacuum port if you want, but I usually use a spray aerosol throttle body cleaner. With the engine off, remove the intake hose from the throttle body. Spray the throttle plate and bore with cleaner. Open the throttle plate to make sure you get the whole bore as well as the plate covered. Using a small reasonably soft brush, gently scrub the throttle plate and throttle body. I like to use an old toothbrush. Use a soft cloth or dampened paper towel for the final wipe down if needed. When you start the engine, it will run rough for a moment while it cleans out the cleaner (and junk) from the cleaning. You may need to hold the throttle slightly open to get it started. Once the engine has settled down (usually within a minute or two), shut it down. Make sure the air filter is in good shape and clean or replace if needed. It is my practice to also add an injector cleaner to the fuel tank after doing this to help clean the injectors. If the fuel filter has net been changed in the last 30,000 miles (some people say 15,000 miles, your choice) this is a good time to change it too.
This does not need to have an oil change or spark plug change after doing this, but if you are going to do such services, it is better to do them after so that you don't take a chance in fouling new plugs and you can dump the junk out of the crankcase.
This service will have effectively cleaned your throttle body, the intake manifolds, the valves, and the combustion chambers. The need to actually remove the intake for physical cleaning is greatly reduced.
I do this fairly often, about every 10,000 miles. It ALWAYS makes a very pronounced difference in how the engine runs. I have not had my upper intake off, but I would be willing to bet that if it were take off shortly after such a cleaning that there would be minimal build up on the secondary plates. Every car would benefit from this kind of service at least every 30,000 miles. By the way, you don't need to remove the upper intake to change the rear spark plugs. There is a how to in the FAQ section. It helps to move the coil pack, but some have reported that they don't need to. To remove the coil pack, a 1/4" drive 7mm flex socket is most useful. Make sure that you don't forget to replace the ground strap and the radio noise supressor when finished. There are four bolts holding the coil pack. You really don't need to reinstall the rear two if the two front ones are properly tightened.
[/FONT]
