99SEinLivonia
Personal experience says pull the darn thing
Ok, a few simple items. I cleaned my intake in-place with injector-cleaner at ~145K miles for the first time after getting IMRC 'stuck' codes. Bad idea! I had to replace three of four O2 sensors within 100 miles afterwards.
Pulled UIM/LIM after as I still had IMRC codes popping up. Gaskets were apparently leaking air badly. I say this because I found carbon-tracks crossing the line of the seal in at least five of the runners. I've got the photos if you're interested. New seals with additional RTV-BLUE - BLUE is sensor-safe....
Cleaned everything very carefully. Used a die-grinder to do a simple port-match for about two inches into the UIM (from LIM mount surface). Very nice improvement. No codes any longer.
Repeated the dis-assembly, cleaning, port-matching on a buddies 96 SE with very good results, in less time and without having to change sensors, oil, etc. Would highly recommend this last option!
-JF
Then an oil change![]()
-JF
