Matty K
Mr. Haines says there's a supercharged 3L running on an OEM. Dunno how long, but it's apparently been a while..... TRicker ran N2O on a stocker for a long time, too.
I have pictures of the second clutch that failed. The complete back friction surface of the clutch disentegrated within 15 miles of installing it. I guess the point here Todras is WHY do you continue to recommend spec clutches to people when it is proven that there are often problems with them? Take a hike over to the mustang furums and read about specs reputation. 2 Stage 1 Spec failing in 18,000 miles for me and the noise problems of this Spec Stage 2 means I will never use one of their products again. Roll your eyes up in your head and GET A CLUE BUDDY!!! SPEC IS GARBAGE.
Mine is going out after about 18k miles as well. I'm not happy with it at all. After all of the bad things I heard about centerforce, I don't see how it can be any worse than my experience with Spec. (product, not cust service) But I don't know what to think.:blackeye: I'd like to upgrade to a stage 3, but how many times should I give my $ to Spec before I learn my lesson? Hell I'd buy an OEM SVT clutch if I thought it would hold up, but I've heard mixed opinions on running those with 3L's. I may have to try a centerforce clutch that everyone always talked down.
Yeah, but were you guys preparing the flywheel correctly when installing this clutch?
Was the flywheel two-step surfaced? Lots of variables here. I don't mind your assessment as long as it is qualified with all the details. After we get detailed we can see if it is the fault of the clutch or the preparation for the clutch.
The second stage 1 that failed had a new flywheel. The clutch WAS defective, LOL THE THING disentegrated IN 15 MILES. 3 three Spec clutches installed in 18,000 is absurd. Beyond a issue with resurfacing the fly wheel there is not anything you can do wrong on a install to cause it to wear out this fast. A clutch ONLY goes in one way. Then you gotta just make sure you bleed it properly. Spec has problems and anyone that puts one in now is risking doing it again very soon!!!!!
BECAUSE YOU'RE THE ONLY ONE WITH A PROBLEM! No one has reported an issue with one on a Contour but you. Tons of people have them on here. I have one and I've installed 2 other for people w/o any issues. They dust a little more but big deal.
what bad things have you guys heard about centerforce?
