Dyoel182
Addicted CEG'er
In my experience its pretty normal for sway bars. I've pulled sway bars off Texas cars that never saw snow or road salt but they looked like they had.
...the rubber on the strut mount was so worn it was egg shaped, alowing the strut to move around and make banging noises.
Is this something I could see by emptying the trunk, pulling the carpet back, and riding in the trunk while the wife drives over potholes?
No. The rear strut mounts are installed entirely from the outside of the car and can't be seen from the inside. You will need to remove the strut/spring assembly to see the strut mount. However, it isn't all that hard. Also, I would find it less likely that this is your problem. The most common cause for "clunking" or "thumping" from the rear suspension seems to be blown struts, and bad sway bar bushings/end link bushings.
I doubt that nut would be a problemWhy would you need to mess with the top nut with the assembly still on the car?
I doubt that nut would be a problem![]()
Thats why I went to autozone.
