Wien_Sean
I will take a picture before I go to work tomorrow, when I have light. Then I can show you guys what tube I am talking about. What Adam has posted is the way the IAC is right now.
Hey! That brass nipple is a primary vacuum port and should be used for the EVAP system that runs up the firewall behind the motor (the tube that used to connect into the pcv valve...It has nothing to do with IAC...if you don't use it plug it.
Everything is either plugged up or connected to something. There are some hoses that run behind the engine, by the firewall, that are just connected to each other. Adam and I were wondering about that. I'll wait for Adam to weigh in on the vacuum port for the EVAP since he knows where all that stuff goes.
the evap hose looks like wire loom, and has a crazy grey connector on the end.
The car is not going anywhere though, my Oil Filter Relocation kit started spraying oil all over the subframe where the old oil filter was, while I was driving to work. On my lunch break I need to jack up the car and feel around for where the leak is.
