This is what i did on my 96. From my build.
Thumbs up
"""SVT gauges are IN the 96 SE!! THANKS KyleH..... Works perfect. Speedometer set with GPS. All that was needed was to swap the SVT E1 white faces from the fuel, temp and tachometer to the pre98 SE gauges. Then mount them back into the 96 cluster. The complete Speedometer from the SVT went right in as well with a bit of work. Just had to trim the mounting post with a razor and cut off 3 of the 6 connection pins. The ones to the side.
I will fill up with fuel in the morning to set the Fuel gauge. Tried out the SE white needles instead of the SVT orange ones...kinda cool all white!"""
